What is this???????? | Page 3 | on ElectriciansForums
Discuss What is this???????? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
as said in a previous post. check battery. as the PP7 is now obsolete, stick a couple of PP3s in parallel, with a bit of foam to stop them rattling about.
I have one in the garage in a lot better condition and have used it on and off for the past 20 yearsI got it as the plant were throwing them out .
Do you think I should take it to Dickensons Real Deals:cool3::cool3:
migtht get a better price for your zimmer frame. LOL. :rofl:
Hi,
I have just found an edgcumbe peebles in the shed, along with a Fluke 12 multimeter.
Where is the best place to sell them as I will not be needing them.
Jill
The pic shows a combined I.R. and continuity tester. They were used in the mines and as such are not suitable for class 11 equipment. I still have mine from when I worked down the mine in the northeast.
Reply to What is this???????? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It maybe a case of the display has died, especially if the unit is actually working, but as James has said you could be opening a can of worms...
You need to look for test equipment that is rated to at least CAT-III and 300V for typical domestic circuit testing, but ideally CAT-IV and 600V...
