what is this? | Page 2 | on ElectriciansForums
Discuss what is this? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
That is a PME supply - send it to the DNO and ask them i that is their work or not.
It does not look like DNO (but I might be wrong) - the question is where does that other earth go to? a rod? bonding?
If its bonding you will need to reroute this via the CU so the RCD can protect the bonded supplies (Water and Gas)
I’m intrigued, how does a RCD protect the water and gas?
Never seen anything like this before!! And Not a PME warning label in sight, i'm ''still'' very suspicious, i'm afraid!! I certainly wouldn't leave that braid N-E connection in place if it were my house!!!
These new age meter men wouldn't know any better and would just re-seal willy nilly, so i wouldn't put too much weight behind it being sealed!!
Reply to what is this? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Even if it’s says that the neutral is bonded to the generator, you still are required to install a ground wire from the generator to the transfer...
You would treat it as a TT installation.
