What Mistakes Have You Done? | Page 5 | on ElectriciansForums
Discuss What Mistakes Have You Done? in the UK Electrical Forum area at ElectriciansForums.net
Paul.M
Supporter
Lost in Space
On site today and I had an Ashley backbox that was loose on one side because the plasterer is rubbish (another story). Anyway, I thought I'd do a quick fix by putting some fire foam on the dodgy side to hold it in the cavity wall. The walls are full of the stuff anyway.
I'm there putting a bit in at a time so not to over fill the void. Ok a bit more as nothing is showing. Ok a bit more, still nothing foaming back at me. Ok a lot more until it starts foaming back at me..... That was a bit of a mistake.
One of the building site labourers said "are you sure your not going through the other side?"
Me "No, don't think so mate. Let's just have a look to check." Then I saw this coming out of the other room:-
[ElectriciansForums.net] What Mistakes Have You Done?
Paul you rounded door handle. I've only gone and put way too much in and its now running down the wall like a slow moving waterfall! Btw this picture was taken just as the flow began, ten seconds later I was too busy to take a pic but it was worst than that!
Twenty mins spent cleaning the foam from the other backboxs and cables, another 40 mins cleaning the bloody foam from my hands and screwdriver, what a prat :). Oh, that's a ÂŁ40 socket that I've just wrecked, its in the bin, they can clean it if they want because I'm not.
Head spark just laughed at me and then banned me from using the foam gun again unless supervised! Think he was joking but I'll put that to the test tomorrow :):).
Lesson for today Paul, don't be out done by the words of wisdom from a builders labourer again lol.
What silly mistakes have you done in the past? This could be an interesting thread if people own up?
Doing an annual EM test in a restaurant when a plumber asks me to disconnect a food drainage unit that he needs to unblock. I disconnected it so he could pull it away from the wall and this thing stank like hell! Full of 2 day old food, it separates hard food and liquid then pulps it into mush.
A bit later on and the plumber asks me to wire it back up so I did. Whilst I'm crouching down next to the start button I turned it on, big mistake! All the waste food in the hopper from the past two days shot up into the air, hit the ceiling and walls then gravity took over and it ended up all over me. I just stood there infront of the chef, plumber and a kitchen porter with bits of spaghetti, chicken, veg, fish bones covering every inch of me from head to toe. I even had a piece squid dangling from my glasses! I looked a right state and it stank. After all the kitchen staff, waiters and management came to have a look at what all the noise was for, I had the restaurant in stitches. They was very nice and let me use the staff room to clean up and gave me a company tee shirt. I powered up the EM lights, got into the van and went home for the hottest shower I've ever had, phoned the boss to tell him that I'll go back tomorrow to finish off the test. Every time I look at that tee shirt I swear I can smell that god awful pukey food, I'll never forget that smell.
Worst mistakes I have made:
Picked up a soldering iron with my hand, on the element, while...still....hot ¬_¬
Found a strange chip, looked at it, held it, found out it was static sensitive......poof!....gone :'(
7805 voltage regulator, output voltage was not correct, maybe turning up the input voltage will help! Hang on, heat? oh, connected wrong way round, the 7805 never worked again.
Memory chip in old commodore 64, took em out and replaced with a single 64KB memory chip, turns out it was a PLA problem, memory was fine >:|
Reply to What Mistakes Have You Done? in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
That explanation would make a lot of sense and would certainly explain the new bases and new boxes, with old relabelled alarm heads. I do remember...
