What multi function test meter? | on ElectriciansForums
Discuss What multi function test meter? in the UK Electrical Forum area at ElectriciansForums.net
K
Kathir.Sris
Hi all,
I am attending a Competence in Testing course and that course requires for me to take my own test equipment. Can anyone kindly recommend a reasonably priced multi-function test meter that meets all the tests for 17th edition please?
Many Thanks
Kathir, doesn't your company own a Multi Function tester? as they are not cheap about ÂŁ500 : and upwards, what course are you taking? Surely your company must have one being an Electrical Services company.
Hello Pete, The Company was registered only a month ago as a new starter and just building up slowly. I am just in the process of registering with one of the organisation that provides Electrical competent Person Scheme, I am attending "Competence in the installation and testing of Electrotechnical systems" recommended by this organisation.
It depends on what tests you will need to do.
The cheapest tester from the forum sponsor test-meter.co.uk is the Seaward Powertest 1557 Part P Tester at ÂŁ299+vat but it does not do phase rotation or RCD ramp tests.
The next one is Metrel MI3125 Eurotest Combo Lite at ÂŁ329+vat that does most of the tests you are likely to need.
However it depends if you want a long term tester or just one for the assessment.
If this is a one off and you are planning on getting a quality tester later then it might be more economical to hire one for a week.
Thanks Mate, just out of interest how long does this course run for? I only ask because I suppose it boils down to what sort of work you intend to focus on once you are up and running. Any how good luck, hope it works out for you.
Reply to What multi function test meter? in the UK Electrical Forum area at ElectriciansForums.net
Hello fellow sparks, I’m looking to do my testing and inspection course which starts on the 30th of April, but I have not got much testing...
I hope this is not a trend by our energy companies....... a 200KVA supply is pretty standard for larger commercial . Are you sure you are talking...
