What on earth is this attached to a consumer unit | Page 2 | on ElectriciansForums
Discuss What on earth is this attached to a consumer unit in the Talk Electrician area at ElectriciansForums.net
The spacing factor for that trunking is looking spot on too, I take it these 'sparks' don't think it needs applying in domestic as I see this all the time.
I stupidly didnt take a snap of the instructions, was on a flying visit. The brand suggests its for or from a caravan oddly...
I took these other pictures though and could not identify a trip nor the reason behind there being both a digital and analogue meter. This combined with the mystery timer has us very confused.
View attachment 31746View attachment 31747
It's a solid-state two-rate meter and a Sangam0 80A Timeswitch, used, for example, for Economy 7 tariff. The grey wire linking the timeswitch to the meter switches the rates on the meter.
Hi, I am im in the middle of buying a house and came across this odd thing that one electrician cannot identify, Its hard wired to the consumer unit... any ideas?
The numbers 1 to 7 at the bottom of the display suggest it could be some kind of 7 day timer. I'd be up for pushing the 'menu' button and seeing what options it offers you, or if it has an override button on it see what comes on when you operate that. Alternatively your "electrician" should have been capable of identifying what it does from what circuit it is on and possibly which direction it goes off in.
My first impression was that it could be an energy meter to tell you how much energy you're using. Is this a possibility?
Definitely a timer. Merlin Gerin to match the MCBs
15720 Merlin Gerin | 7 day 1 HP 1 channel timer w/LCD display | 399-5620 | Welcome to RS Online
Right then,
So the Sangam0 80A Timeswitch. This is for multi tariff management potentially?
The Merlin Gerin to match the MCBs, could this be a timer for the towel rail or outside lighting or cannabis farming?
And the consumer unit doesn't have any RCDs has it? is this effectively unsafe if there is a fault?
This has been a really big help guys! great stuff.
Right then,
So the Sangam0 80A Timeswitch. This is for multi tariff management potentially? Correct
The Merlin Gerin to match the MCBs, could this be a timer for the towel rail or outside lighting or cannabis farming? This circuit would need to be traced to verify it's function
And the consumer unit doesn't have any RCDs has it? is this effectively unsafe if there is a fault? Not unsafe as long as the existing circuits disconnect within the required times. RCDs would provide an additional level of safety.
My thoughts in red.
This is a digital time switch.
It looks like a schneider IHP model without the plastic see through cover
Hope this helps
Reply to What on earth is this attached to a consumer unit in the Talk Electrician area at ElectriciansForums.net
Only his early stuff.never muched like any stand up comedians .although the only one I've seen live was Roy chubby brown in the 90 s .can't say I...
Yes that does appear to be the case. I may get an electrician to fit the correct glands. Thank you.
