What socket is this? | on ElectriciansForums
Discuss What socket is this? in the Lighting Forum area at ElectriciansForums.net
Pashley
Doncaster
Hi Everyone! New hear and looking for some help regarding a socket on a floodlight. Not sure what type it is, I think its a G24q but not 100%. Does anyone on here have an idea which it is? And assist in what type of bulb to get for it?
Image is here: Socket-Type - https://ibb.co/Ksz3tgx
That looks like a socket for a compact fluorescent lamp.
If you change it to a normal light socket then you may well need to remove the controll gear Fromm the fitting.
Hi James, so would you say a G24q-2 bulb would fit this? I've seen there are 3 different types of G24q's and not sure which would work.
As you mention, there are several variants of G24q lamps, with 2 or 4 pins, and some with tabs that fit cut-outs in the socket in a specific place - designed so you can't put the wrong lamp in the lamp holder.
in the past with a non-standard variant, I've taken the old lamp to somewhere like CEF, and checked the new lamp base is identical before buying it.
Reply to What socket is this? in the Lighting Forum area at ElectriciansForums.net
For my hapeneth and learnt from hard recent experience, the term LED transformer and driver tend to be used interchangeably, when they are...
Here is my first design, I realised I can print onto clear acetate, so black areas will allow less light to come through and the lined areas will...
