What type of fuse this is? | Page 3 | on ElectriciansForums
Discuss What type of fuse this is? in the UK Electrical Forum area at ElectriciansForums.net
banny07
I came across this fuse twice. Could someone here let me know what type of fuse this is.? I need to fill EIC.
You pulled the fuse live though, which is probably more dangerous than tightening a loose neutral.
What would you do if you find neutral terminal on main switch damaged due to heat and you can not properly tighten it? I did what I thought was the best option at that time.
Reply to What type of fuse this is? in the UK Electrical Forum area at ElectriciansForums.net
Apart from how you extend all the cables
And with a duff one, it just sits there, not knowing which way to turn, but drawing considerably more than its normal run current.
