whats with all this volt drop crap? | Page 3 | on ElectriciansForums
Discuss whats with all this volt drop crap? in the UK Electrical Forum area at ElectriciansForums.net
A
ayjay
posters on here often worry about volt drop, whats the prob with a few less volts @ the other end of the cable? will a few volts less end in disaster? will the suppy cable catch fire?
be nice i,m mellowed out at the moment:mickey:
Volts drop is proressive along the customer supply chain if you got the furthest house at 230v spot on then the nearest house would be higher..... .
I've worked on many houses over the years in the most remote, and the most built up locations, and I don't think I've ever found one to be below 240v. In fact, most are in the region of 245v.
With the greatest respect to you dark, if you work in the industrial/commercial sector then the domestic scene would make your hair curl (as it did mine when I left industry) :)
Industry has always stuck to the higher end of the voltage range. I’ve worked on 550V and 660V systems. Uses a lot less copper for the same amount of work done.
PS you don’t use phase to neutral! Beyond the intake switchgear neutral isn’t required so not run.
Reply to whats with all this volt drop crap? in the UK Electrical Forum area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
