What's your lowest Ze recorded on a TT system | Page 2 | on ElectriciansForums
Discuss What's your lowest Ze recorded on a TT system in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
4 ohms is pretty darn good. Think my previous lowest was about 28 ohms.
I thought that I had gone through something at first:), but i've been on the job before the garage was biult ie. when they were digging the foundations and preparing the ground for the garage there was nothing there and the supply comes into the grounds of the property on an over head line so I haven't hit that.
Wouldn't surprise me in 25 years of sparking never seen a set up like this. Would be interested to know if this type of earthing is common practice in Paris or France in general.
Did a lot of installation work at euro-disney and yes this is commonplace in France.
They love their TT and run loads of tapes round everything, at E-D every ride/stand etc had its own tapes run round it - dont ask me why, I was just there chucking these things in the ground because they were paying a fortune and it was no brain donkey work :)
Will have fantastic scrap value for whoever gets to rip it all out in the future!
I am going to have to but in here and claim the all time record low for Ze on a TT system.
In Paris last week testing a new installation tested 0.14 ohms for a Ze on a TT (couldn't believe it).
The installation is a large office complex with a 3 phase TT supply. Main incomming cables are 240mm with 120mm main earth. This part of the installation was existing. After a lot of investigation as to the type of electrode used it was established that the 120mm main earth was conected to an earth plate buried in the courtyard of the building. From this plate a tape was run underground around the perimiter of the building and back to the earth plate in a ring.
Hope this gets me into the guinness book of records for lowest Ze on TT.
Out in Paris again last week to finish testing when i was made aware that there was also an earth tape connected from the earth plate to the district steam supply.
Apparantly these district steam pipes go underground for miles and supply heating to the entire city.
Now i can understand the low Ze.
bugger cant beat that my lowest is 36ohms
but i may be in the running for the highest 386......
in cornwall ina village built on mining spoil...nice
mine waste drains well i guess.
round the corner a house garden fell into old mine workings!!!
this is 100m from the door of my said property!!
you need some earth to get good earth init??
Reply to What's your lowest Ze recorded on a TT system in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
