Where to connect power cord to induction single phase motor 240v | Page 2 | on ElectriciansForums
Discuss Where to connect power cord to induction single phase motor 240v in the Australia area at ElectriciansForums.net
Joe9009
Perth
[ElectriciansForums.net] Where to connect power cord to induction single phase motor 240v
(I would want it to run clockwise)
Any guidance would be much appreciated.
It runs without the earth wire connected
what do you think?
the tray that's screwed on to hold the capacitors, i suppose i could connect the earth wire on one of those screws if need be?
Reply to Where to connect power cord to induction single phase motor 240v in the Australia area at ElectriciansForums.net
Hi, Thanks for that, you learn something new almost every day! Regards Griffey
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
