Which diamond core cutter set do you use? | Page 2 | on ElectriciansForums
Discuss Which diamond core cutter set do you use? in the Talk Electrician area at ElectriciansForums.net
Having struggled with a painfully slow core drill for a while I stumped up the cash for an SDS max drill. It's a monster and will do 50-60mm holes in concrete with a percussive drill. It takes about a tenth the time of using a core drill.
Reply to Which diamond core cutter set do you use? in the Talk Electrician area at ElectriciansForums.net
how often will you need to use it? Would renting one from a tool hire place be more cost effictive... and might give you an idea of good brands...
Also good for cutting strands of cable armour, although I try to restrict their use to copper.
nicebutdim
N
