I have only installed the MK version of A3 CU's, mainly because of their pleasing looks
However, after trying to straighten the mcb's etc on the last 3 I've installed and failed, I'm kinda getting less enthusiastic about them. The final nail in the coffin, was trying to connect up some RCBO's, where the CU was located close to the ceiling, where because of the design of their RCBO connections, it was impossible to see if the neutrals were properly terminated, ended up taking RCBO off the din rail, terminating cables, and then placing back on the di rail (see pic below). Also the room available to dress the cables/conductors is limited (especially with RCBO's), made it look a pigs ear, admittedly not my best area
![MK7932S[1].jpg MK7932S[1].jpg](https://electricians.s3.eu-west-1.amazonaws.com/data/attachments/30/30586-1fb354c1e399e8c560decdea24502585.jpg?hash=H7NUweOZ6M)
So, with some new CU's to be installed in the New Year, what makes do you install & why. I'm leaning towards the Hager Design 30, due to the layout inside?
