Discuss Which screwdrivers? in the Electrical Tools and Products area at ElectriciansForums.net
Looks like Facom aren't any dearer than the Irazola.... I'm sure Irazola were far better before being taken over by Bahco. Thanks for the advice, I will try a set of Facom unless someone comes on here telling me how ---- they are!
Facom are ----
Only joking, not used them but they have a good rep
I use Wiha. I don't use a 4mm but a 4.5mm for socket terminals, and a 3.5mm for switch terminals and the like.
Their blades are 1.0mm thick in 4.0mm to 5.5mm which means a snug fit in socket terminals and 3.5mm screws, but a bigger beefier driver can be used.
I have a set of Wiha which I bought just to rob the smaller blades from. There was no 4mm in the set though. Problem is I have loads of new big screwdrivers and always needing the smaller blades, shame no one sells a set of small blades. I tend to use the 4mm for sockets and switches, but maybe I should do as you do and use a 4.5 for sockets, particularly the MK sockets which seem to have larger slots to their terminal screws.
Hi Happyhippydad... a good poll, have you done one on cutters too? I've yet to find a decent general purpose cutter...
Reply to Which screwdrivers? in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
