Which screws do you use...? | Page 3 | on ElectriciansForums
Discuss Which screws do you use...? in the Electrical Tools and Products area at ElectriciansForums.net
If you fit back boxes using a long length of M8 threaded rod right through the wall with a washer and a nut on both ends they never fall out.
only if you use nylock nuts. otherwise vibration over time could loosen them. like a tart's knickers.
if fixing directly to brick, (no plaster) then 1" screws will suffice in most cases. generally though, i use 1 1/2" x 8's. like using the square drive (robertson) heads, just to pee off the next bloke.
They're universally used here - usually referred to as square heads or Scrulox (but they're also known as Robertson).
Not a bad way to secure (no pun intended) repeat custom ? Bet that's why you do it @telectrix eh?
Unfortunately here it doesn't guarantee repeat custom as every spark uses them. A pozidrive screw might ensure that they have to come back to you with your weird security screw though!
Reply to Which screws do you use...? in the Electrical Tools and Products area at ElectriciansForums.net
Also good for cutting strands of cable armour, although I try to restrict their use to copper.
nicebutdim
N
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
