which size swa | Page 3 | on ElectriciansForums
Discuss which size swa in the UK Electrical Forum area at ElectriciansForums.net
diytom
Hi all, Im just looking for some guidance with swa cable and the sizes that I should use. We are wiring a consumer unit in the garage/shed from the house cu. My mate is a sparky and he said that if I can do the donkey work so to speak he is happy to come and make all the final connections and test the circuits for complying with the regs. He did state what size swa to use but that was a few weeks back and at present he is on a months holiday abroad so one cant check. The garage/shed is on a 3 mcb + incoming mcb cu. These mcb's are 32a, 16a and 6a. There are 3 circuits, the 1st on the 32a mcb is radial and supplies 4 dbl sockets, the 2nd on the 16a mcb supplies a single socket connected to a tubular heater and finally the remaining 6a mcb supplies the single baton tube light. The run from the grage/shed cu is approx. 10 - 12 meters and is to b e terminated at both ends into metal junction boxes ready for connection to the respective cu. One site sparky I spoke too simply advised the bigger the better, but others have said you may be able to utilise 6mm as it is unlikely for us to use all the sockets at the same time, two sparkys advised at least 10mm and one stated 16mm would be the way to go. However my employer has offered me a roll 24 meters of 6mm 3 core pvc sheathed cable, one opinion is that we can use this in conduit and run two lengths of cable from cu to cu, one supplying the 32a mcb radial circuit and the second to the 16a and 6a circuits. I have approx. 10 days before my mates return to run the cable in anticipation of him making the connections a couple of days after his return.
i've got some 1.0mm T/E min red/black from a strip-out he can have. owing to it's antique value, i could not consider anything less than £100. i'll even throw in a 5A 3036 complete with carrier.
Don't you mean ''Unique'' value??
I can see some distinct advantages for the DIY Dave's as well as other unscrupulous characters of this world!! lol!!
Ok, I'll be serious now, clearly 400mm 4 core is over the top and a flippant response was unprofessional, the way you describe the circuit it's perfect for long range electromagnetic induction, you need to buy yourself a small 11-15kV Tx (like one used for neon lights), put a plug on it and be ready.
In your garage you need some hard drawn annealed wire that is varnished (Mapin have some) and then wrap about 30m of this around a steel core, a bit of cast iron down pipe will suffice. Make sure your wrapping is tight and tidy, using masking tape to hold down the layers. The length of the winding should be between 280mm and 302mm, and 30m should give you about 80 layers. The two ends of the wire need to be terminated into a connector block and the output can then be used on a normal extension lead.
Voila, 11kV in when you plug in the Tx and you get FREE 235V out the coil...and the electricity is Free too!!
See, we do give out proper advice..
My Doctor is on Holiday, can I start a thread to seek advice from you professionals because I am sure he isn't...he doesn't even speak English properly..Well he is Welsh, what should I expect!! :D
Reply to which size swa in the UK Electrical Forum area at ElectriciansForums.net
Haha yes, it is. Must be a northern expression. Have a Google 😂
