Which Tape Measure | on ElectriciansForums
Discuss Which Tape Measure in the Electrical Tools and Products area at ElectriciansForums.net
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
screwfix doing a 5m and a 8m milwaulkee for ÂŁ9.99 the 2. nice tapes.
For those that have never seen the Festool tape, you read the measurement from the top window so the overall length of the tape and housing is used, good for inside measurements, the radius marking is between the fold out point and a pencil hole in the tape about 25mm in, the dimension/radius is also read through the top window on a different scale, these markings are on the underside of the tape when pulled out so the tape can be used conventionally with the tape extended and read as normal.
My local screwfix has a twin pack of Stanley 8m tylon ones for ÂŁ9.99. i treat them as expendable, and that's a cheap price. If you break one, a wetpants "borrows" one, or you simply lose one, they're cheap enough. I have about 10, 1 in each bag and elsewhere in house and car.
I also use a Leica Disto2 laser measure for some jobs, and it is excellent...but quite expensive.
I have loads lying about in various tool boxes too, along with small spirit levels that I can never find on the spot. ;)
They all fall through the rip in the space time continuum that devours my pencils. ?
No matter all the fancy tapes I have to one I use the most is the 2m FatMax Stanley, fits in the pocket without pulling my trousers down. ?‍♂️
I often use a digital measure, but never trust them for accuracy. Hard to beat reading a tape.
In defence of digital measures, I like that they make calculations for height etc.
I used to have an Engineers tape that came with a spring balance to load it to the most accurate length just above the ground, this was before obtaining the Wilt T2A theodolite with distomat accessory, that was accurate to .005mm as long as the wind was not blowing the target around. ?‍♀️
year or so ago i bought a 8m tape with a 30m laser range measure. never use it as a tape. it's calibrated in metric only. use the laser then have to transfer the reading for translation into english.
The lad got a Kline bundle from CEF as a started tool kit and in it came their tape measure and it is very good.
So, kline I guess. ?
i have been looking for a tape with fractions on, I hate mm . i wear glasses now so bigger marking will help ,and yes have been to specsavers .
here be wot yous needs.
and no mm.
Reply to Which Tape Measure in the Electrical Tools and Products area at ElectriciansForums.net
Tape for pipe insulation Does anyone have recommendations for tape to seal the seams in foam pipe insulation? Most tape seems to get brittle over...
siricosm
T
What plumbing tape is recommended for a copper waste water pipe Hi there, We have a leaking waste water pipe which our washing machine, boiler and...
Tellie
T
