G
Geordie Spark
does anyone know how expensive solar tiles work out to be?
thanks
Have you tried Google? ................... and a compass ???
This thread titled "Which way is my roof facing?" is posted in the under the Solar PV Forum | Solar Panels Forum on Electricians Forums.
thanks
Yes, I have been using google and other search engines for around 17 years.
Was just a question, why the attitude?
Just thinking outside of the box here but...
Do you get on well with next door and would they consider Solar?
If so I'd fill up your SE facing roof with solar panels for both of you, you would be able to put alot more on then and the would get a better payback and more electricity generated then faffing about with the current hip end, or putting panels on dormers. Plus it'll be a little cheaper for both as you are sharing scaffolding and roofer costs.
Obviously if you are doing an extension with dormers than this isn't an option.
Just a thought!
google maps?
OS online?
local searches?
watch the sun come up?!
Customer may be partially sighted, blind or suffer from an extreme version of parallax error, due to pronounced eye squints.
In that case all the above would be useless.
:13:
very....does anyone know how expensive solar tiles work out to be?
thanks
Reply to the thread, titled "Which way is my roof facing?" which is posted in the under the Solar PV Forum | Solar Panels Forum on Electricians Forums.
