Why coil the earth? | on ElectriciansForums
Discuss Why coil the earth? in the Australia area at ElectriciansForums.net
Why do some sparks do about 5 coils before the bonding clamp, others don't!
Really can't see the reason for adding a few coils!
Off the top of my head
It gives flexibility to the cable which may reduce strain on the joint
It allows for a new connection to made where corrosion or damage occurs
It looks the part compared to a rigid straight on connection
[ElectriciansForums.net] Why coil the earth?
It allows movement for ease of decorating
Finally coiling the slack tends to calm the nerves of a spark who needs to fidget while arguing with the customer
well its the same as when you are drawing cable/s in to enclosures isn`t it.....you dont want those cables pulled tight do you.....leave some slack in em......enough so you can make em off again if the termination fails.....same here innit.........and as has been mentioned by Des......to allow for the wetman to correct his mistakes......
It should NOT be done. Look in to inductance loops under high current flow. OK it looks pretty but serves no useful purpose what so ever. Other than limit current flow, which you DON’T want.
How to upset a contractor in one easy lesson, “those nice twiddly earths you’ve fitted, rip the lot out!”
Reply to Why coil the earth? in the Australia area at ElectriciansForums.net
Hi, How did you get on with the wiring?
If there's no main switch on the CU, then the RCD is doubling up as the main switch and everything is protected by it. If there is a main switch...
