Why do we do it the way we do in the UK? | Page 4 | on ElectriciansForums
Discuss Why do we do it the way we do in the UK? in the UK Electrical Forum area at ElectriciansForums.net
Electrics
Nearly Esteemed
Essex
Was just watching a video of an RCBO install and found it weird that the breakers are double pole yet still have to have a fly lead.
Why don't we do it like this:
Ignore the gibberish coming out of his mouth and take a look at the unit. L+N coming from the supply, feeding the bottom of the first RCD. All the RCD's are linked together by the linking bars running down the left, giving them all L+N feed. The feed then goes through the RCD out the top, into the bus bar that's linked across the tops of all the MCB's. The L+N of each circuit comes out the bottom. This does away with the need for a neutral bar (there is one but they are used when there is no linking bar employed and you have to run an N to each RCD), several main neutral cables and the need to fill the unit with loads of extra cabling, not to mention cost saving on the materials.
Why, even with dual pole RCBO's, do we still make them use fly leads when we could simply link them all to N via the main RCD in? Makes no sense to me.
Having said that we're still the only country i know of that uses rings.
Anyone think we'll eventually catch up and stop doing things in such weird ways? Although i guess one drawback of the way they do it in Europe is that their multi tier units are standard for almost any regular sized home and they are anywhere from £3-700.
Just getting round to having a good look at that
DP Isolator and ssd's part of the changes to rules
Bathroom and general lighting now shared on rcbos, single pole(note the sign lol, no ir testing at load terminals, dunno about that likely a backward step imo )
All type A 30ma protection , think Hagers been that way for a while ?
Presume you're fitting control for 2 instantaneous showers?
No. It's just one shower. But from now oni, m going with a Co tractor and running a 10mm straight to shower. I had hoped to have the DB installed today but could, nt start until late afternoon. Anyway have a, peeka at the attached pic
  • [ElectriciansForums.net] Why do we do it the way we do in the UK?
Ah yes ok but there is a problem with that method and I've seen it in use occasionally
I presume you're running a control pair to a switch to control the supply to the shower
The problem is that unless you break the 10sq supply using an Isolator you're not actually providing local isolation
I would stick with the isolator, a crabtree ceiling mount Isolator works well
Yes. There will be an "on/off" control switch outside the door.
I, ve not heard that particular take on it myself. I do know that this method of installation is becoming increasingly more common. I also think that most 40/50 amp isolators are not adequate for 10mm.
Reply to Why do we do it the way we do in the UK? in the UK Electrical Forum area at ElectriciansForums.net
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
