Why my breaker tripped?
yes two small tripped breakers near each other. One for lights in house,second for power in wall sockets.
Why i lose a power circuit too when a bulb blowed on a lighting circuit?
why power in wallsockets go out and lights at the same time? its as expected?
RCD ( that biggest on left ) not tripped.
When a breaker trips it will take power off lights and receptacles. It all depends on how the electrician wired it up so yes that’s not unusual
So it was normal when power in whole house goes off and lightings off too?
I’m not saying that you are loosing ALL power I’m just saying that a lot of electricians put lights and some receptacles on one circuit. Are you saying that your main breaker is tripping?
No,the main was not tripped. But two small circuit breakers. One for power in sockets,second fo lightning. So it can be expected/or normal when halogen bulb wil blown?
