View the thread, titled "Why oh why 25mm meter tails?" which is posted in Australia on Electricians Forums.
sparc
Does anyone understand the logic of 'mandating' 25mm meter tails when upgrading a CU, when the sizing of other cables are left to the electrician's discretion?
I'm again having to explain to a little old lady with not a lot of money that she's need new meter tails with with tiny 6-way board, for her tiny 2-bedroom flat.
Massively cooking range to feed? Nope! 10.8Kw Powershower? Nooooh!
When copper is becoming an increasingly rare resource shouldn't we be fitting what's needed?
My guess is that the IET are simply 10 years out of date, plus someone somewhere calculate the specification, then a sub committee adds 10% to that, and the main committee thinks - let's be in the safe side, and adds another 10%.
Craziness gone mad!!!
(Rant for the day over - thank you for listening)
Thanks for clarifying, but it seems a pointless exercise if you ask me. I regard the meter tails as starting at the meter and ending at the distribution board. Electrically, having a bit of 25mm2 for the last segment doesn't change the overalll current carrying capacity of the tails, which are still limited to 87A by the 16mm segments. - IMHO.
doesnt matter what you regard meter tails as you arent allowed into the meter
round and round and round we go
Correct, but I still don't have a conclusive answer! Some people think the 25mm is not mandatory - you can make a calculation on loading, and use 16mm2 if appropriate. Others think you've got to upgrade to 25mm2 - no option - but say you can't take existing tails out of meter to replace.
I'm going call it quits now, but I would add that - in my experience - opening the part of the meter that gives access to the tail temination block - doesn't give you access to inside of meter. So the seals on the meter don't have to be opened. Maybe some older meters don't have a clear divide like this.
because you dont listen
but it does allow you to bypass the meter, that means free electricity
An installation needs to comply with BS7671 to ensure good practice but is not law, however Building Regs say that work should comply with BS7671 which is law so in a rounadbout way it doesn't matter what you do because IF something were to happen then you'll get it from one side if not the other or both perhaps?
Leave those meter seals intact
The cables from the cut out to the meter are not ours to play with
As flukey,the 25mm tails in the consumer unit can be jointed to whatever is existing,even if they are well undersized 6mm or such
The supplier can be notified to come and make that connection,it used to be £16.
They can then replace the cut out seal (that was removed for safety) at the same time if they want,or not,its their choice, their equipment, their responsibility
If they dont fit the new tails its not your problem, if the meter gets cooked, as long as the connection was requested the problem is theirs
and to work on the meter would mean pulling the cutout which in theory means cutting the seals on the cutout!!! which of cousre you are not allowed to do :rolleyes2:
common sense prevails, thanks des, now time for a beer, or 10 :lol:
Reply to the thread, titled "Why oh why 25mm meter tails?" which is posted in Australia on Electricians Forums.
Australia
sparc,
blowfelt,
