View the thread, titled "Will a 10mm PYRO take 80 amps ?" which is posted in Australia on Electricians Forums.
sycamore89
Hi,
I need to change the main incoming fuse from 60A to 80A but there is a 10mm pyro feeding the property and i dont really want to replace this. The reason I need to up the supply to 80A as I am installing a sunbed which runs at 40A single phase. The load will never constantly be running at 80A so thought that the 10mm pyro would be sufficent.
Property has 2 rings with only a few computers and hairdryers etc.... has no oven but 1 microwave so not much load on any other circuits.
Would this be ok ?
I have not pulled the DNO fuse yet but I will do for safe isolation while I change the cu! Property is fed by a 25mm SWA! And no I'm not a sparks I'm a plumber !!!
Reply to the thread, titled "Will a 10mm PYRO take 80 amps ?" which is posted in Australia on Electricians Forums.
