so. hager say they won't fit. forum brains say they will. i know who i'm going to believe! (forum members aren't trying to sell new CUs)
Discuss will it fit, and is it acceptable? in the Talk Electrician area at ElectriciansForums.net
That's interesting. I just split tails on a TT with just a 100ma timed RCD and CB to feed an swa submain. I assumed the RCD was ok as a main switch. Not so?
Dont want to rain on your parade but I had a problem with a 1361 Hager board as the cartridge fuse had blown and this was sourced to the GU10 lamp blowing fine so the letting agent said we cannot call you out every time a lamp goes how do you fix it so I wrote ta hager and they said no you cannot put a mcb in. Will try and dig this out.
Here you go
Me Technical question:
Hi can you swap over on a Hagar consumer unit a BS1361 cartridge fuse holder with a Hager MCB
ie will a MCB fit
Hagar
Hi
I'm sorry there is no MCB that will fit in place of the cartridge fuse
Regards
Carl
Hager Technical Support UK
Hager Ltd
Hortonwood 50
TELFORD, Shropshire
TF1 7FT
United Kingdom
[email protected]
tel 0870 607 6677
fax 01952 675557
Now I did ask if I could replace the holder and the reply was no you cannot replace the cartridge fuse but I think they meant the cartridge fuse holder (they had better)
Reply to will it fit, and is it acceptable? in the Talk Electrician area at ElectriciansForums.net
