Wire from the blender caught fire, fuses tripped | Page 2 | on ElectriciansForums
Discuss Wire from the blender caught fire, fuses tripped in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Or use a joint similar to the ones being discussed yesterday on the washing machine flex thread. Cut back to undamaged cable and extend with new flex.
As already said, surely the flex could be shortened, job done.
Never done it myself but......
But I can assure you they work a treat when you put an angle grinder through an appliance flex.
Reply to Wire from the blender caught fire, fuses tripped in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Safe: probably. Compliant with regs: No Why has this been done? It's OK as a short term measure before a new CU is fitted.
Have you checked the RJ 45 type lead that connects the pcb to the power supply in behind is properly connected? What voltages do you get at the...
