Wire identification | on ElectriciansForums
Discuss Wire identification in the USA Electrical Forum area at ElectriciansForums.net
Not entirely sure what your question actually is but I’m guessing you need to know that G = Ground and then either Red, Black or Blue are your two hots (any combination will get you 210v ish). However you said 240v so have you bought a European pump instead of a US one? In which case, check that it will work at 60Hz and not 50Hz as it will be spinning a bit faster if so.
Reply to Wire identification in the USA Electrical Forum area at ElectriciansForums.net
It probably was checked,, by A.I,, and found to make purfect scence..
IP68 sockets are similar to IP67, they just take a few days longer for the water to fill them up....
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
