Wire nuts just the ticket | Page 2 | on ElectriciansForums
Discuss Wire nuts just the ticket in the UK Electrical Forum area at ElectriciansForums.net
Skys
Barnsley
Great installation with wire nuts
[ElectriciansForums.net] Wire nuts just the ticket
American owned by Stanley Black & Decker.
Hilti & Makita are two of very few tool brands not owned by large corporations. Think possibly Fein is also wholly owned.
I am guessing Draper Tools is now either owned by the Chinese or Americans ?
To be fair, the problem there is not so much that they are wirenuts, but that they have twice as many wires rammed in (unsuccessfully) as they are designed for, no box to live in, and generally a complete lack of skill used in the installation.
@Megawatt this kind of garbage is what UK sparks often think of when wirenuts are mentioned, not least because they were often used in cheap work. We didn't call them wirenuts then, the name of the most popular brand 'Scruit' became a generic term but a more official name was 'thimble connectors.' Better quality work usually had twin-screw porcelain terminal blocks. Either way they were supposed to be housed in proper junction boxes, although they were often found tucked inside the hollow back of mounting blocks for switches and ceiling lights.
I have to agree with you, we have so called electricians who don’t give a crap. If you use the right size wire nut and not trying to cram 10 wires in the and you tighten them correctly they work fine. Never ever make a splice outside a junction box with a cover and has to be accessible. Some of the idiots make people like me look bad. Sometimes I go out on a job and would like to slap the last so called electrician that work on anything. I get a lot of calls going behind a cowboy electrician who couldn’t fix a simple problem. You are the man. @ Lucien and hope your feeling better
They are selling Scruits in Walsall right now. No good for joining wires really as it's one more problem when testing, having to untwist/stress them, not good.
When ever I have had to untwist a bunch of solid twisted up copper wires they all tend to break off and snap
Reply to Wire nuts just the ticket in the UK Electrical Forum area at ElectriciansForums.net
Agree with SJD. Also the 2.4V you have from the 2 cells may not be enough, but worth a try.
I have to agree with littlespark stating that the wires should be absolutely cut loose at the fuse or breaker to make it safe. The heaters should...
Recommended Sponsor News
Hi everyone,
