Is This is an America code [NEC] code thing only? Or does 17th edition or IEC
have the same thing?
A wire runs between 2 panels is rated to carry 400 amps.
Its fed from a 600A breaker on the line side, and has a 400 Amp
breaker on its load side [the panel being fed from the other one].
Under NEC, we would say thats a code violation because
"a wire is only protected by its line side [feed side] breaker."
Meaning the correct breaker on the wire's load side doesnt
count at protecting the wire.
does 17th edition or IEC say the same thing?
