Wiring a 5 bedroom house | Page 12 | on ElectriciansForums
Discuss Wiring a 5 bedroom house in the UK Electrical Forum area at ElectriciansForums.net
omoeko
London
Hello Everyone,
I am not sure of the etiquette here on the forum, but I would like to start by extending warm greetings to everyone in the house. This forum is very useful for me and I have learnt a lot from it.
I would like to ask a question, its about the list of materials required to wire a 5 bed house. I have the list below, and would like to know if its correct etc.
3/4 double sockets per bedroom, and everywhere will have spot lights apart from the bedrooms. I also plan to use a double electric oven, which is rated at 4,400W and hence a 6mm cable needs to be used. The distance is about 10m from the board to the kitchen. Below are the oven specification.
Energy efficiency class (2010/30/EC) - cavity 2 : A Energy consumption per cycle forced air convection - cavity 2 (2010/30/EC) : 0.80 Energy efficiency index (2010/30/EC) : 112.9 Energy efficiency index cavity 2 (2010/30/EC) : 94.1 Electrical connection rating (W) : 4400 Current (A) : 20 Voltage (V) : 240 Frequency (Hz) : 50
Description Quantity
Non fire rated spot lights (Lounge) 10
Non fire rated spot lights (hall by door) 4
Non fire rated spot lights (family living area) 12
Non fire rated spot lights (Kitchen) 8
Non fire rated spot lights (Upstairs landing) 6
Non fire rated spot lights (Downstairs toilet) 4
Non fire rated spot lights (Utility room) 2
Bathroom spotlights (Upstairs bath) 6
Bathroom spotlights (Upstairs Ensuite) 4
External spot lights for outside 6
Pendant light 8
Smoke Alarm 2
Heat Sensor 1
Extractor fan 3
12/15 way board with MCB's 1
Kitchen Extractor Chimney 1
Shower shaving socket 2
Isolator for extractor fan 3
1.5mm brown cable 100m
1.5mm blue cable 100m
1.5mm GREEN/YELLOW cable 100m
3 core flexible cable 50m
2.5mm 3 core cable 200m
1.5mm Twin and earth cable 200m
2.5mm blue single core cable
2.5mm brown single core cable
Earth bonding
10mm green earthing
2 gang switch 4
3 gang switch 1
1 gang switch 8
1 gang switch white 2
Outside floor light 2
Fused spur with neon light 3
13amp socket plug 2
Double socket chrome 35
Double socket white 6
Cooker switch chrome 1
6mm cable for cooker 10M
6mm armour cable for garage 12m
Coaxial cable for Tv 50m
Coaxial socket for satellite 2
Electrical trunking 75 x 50mm - 2.4 metres 2.4m
Carbon monixide detector 1
50 pieces of open Grommet 25mm
2 Gang External plug socket 1
Hello Everyone,
Pendant light 8
Smoke Alarm 2
Heat Sensor 1
Extractor fan 3
Earth bonding
10mm green earthing
2 gang switch 4
3 gang switch 1
1 gang switch 8
13amp socket plug 2
Would be wrong to confirm or decry another persons list of materials and in the situation where the customer wants to buy the items I would walk away. A regular electrician will have a proper trade account with a reputable wholesaler and should source and recharge for parts including adding a percentage, 20% is mentioned elsewhere and that is reasonable, sourcing equipment takes time and experience and also puts a risk onto the electrician through his account with the wholesaler, its his credit and you are the risk he takes. I have a local customer who has retired to these parts and was a private doctor in London. Told me he charged ÂŁ350/hour and he was worth it because it was he who had gone to college for years to learn his profession. My reply was that we are the same, people who carry out skilled work and are properly trained have studied and are entitled to our rate. Similarly a local landlord
Hello Everyone,
Pendant light 8
Smoke Alarm 2
Heat Sensor 1
Extractor fan 3
Earth bonding
10mm green earthing
2 gang switch 4
3 gang switch 1
1 gang switch 8
13amp socket plug 2
All down to the electrician and discourteous to go crosschecking his list. Non fire rated spotlights seems a weird choice.
you right there ,if customer of mine say they are supplying any materials. I would ask them to sign a piece of paper saying no warranty's of them supplying own gear e.g. non fire rated lightings. if you property burns down .
you can not claim on my insurance.
Ok I'm closing this thread now as it's just descended into chaos and looks like it is never gonna get back on track.
If the op wants it opening again then please send me a pm.
Reply to Wiring a 5 bedroom house in the UK Electrical Forum area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
