Wiring a 5 bedroom house | Page 10 | on ElectriciansForums
Discuss Wiring a 5 bedroom house in the UK Electrical Forum area at ElectriciansForums.net
omoeko
London
Hello Everyone,
I am not sure of the etiquette here on the forum, but I would like to start by extending warm greetings to everyone in the house. This forum is very useful for me and I have learnt a lot from it.
I would like to ask a question, its about the list of materials required to wire a 5 bed house. I have the list below, and would like to know if its correct etc.
3/4 double sockets per bedroom, and everywhere will have spot lights apart from the bedrooms. I also plan to use a double electric oven, which is rated at 4,400W and hence a 6mm cable needs to be used. The distance is about 10m from the board to the kitchen. Below are the oven specification.
Energy efficiency class (2010/30/EC) - cavity 2 : A Energy consumption per cycle forced air convection - cavity 2 (2010/30/EC) : 0.80 Energy efficiency index (2010/30/EC) : 112.9 Energy efficiency index cavity 2 (2010/30/EC) : 94.1 Electrical connection rating (W) : 4400 Current (A) : 20 Voltage (V) : 240 Frequency (Hz) : 50
Description Quantity
Non fire rated spot lights (Lounge) 10
Non fire rated spot lights (hall by door) 4
Non fire rated spot lights (family living area) 12
Non fire rated spot lights (Kitchen) 8
Non fire rated spot lights (Upstairs landing) 6
Non fire rated spot lights (Downstairs toilet) 4
Non fire rated spot lights (Utility room) 2
Bathroom spotlights (Upstairs bath) 6
Bathroom spotlights (Upstairs Ensuite) 4
External spot lights for outside 6
Pendant light 8
Smoke Alarm 2
Heat Sensor 1
Extractor fan 3
12/15 way board with MCB's 1
Kitchen Extractor Chimney 1
Shower shaving socket 2
Isolator for extractor fan 3
1.5mm brown cable 100m
1.5mm blue cable 100m
1.5mm GREEN/YELLOW cable 100m
3 core flexible cable 50m
2.5mm 3 core cable 200m
1.5mm Twin and earth cable 200m
2.5mm blue single core cable
2.5mm brown single core cable
Earth bonding
10mm green earthing
2 gang switch 4
3 gang switch 1
1 gang switch 8
1 gang switch white 2
Outside floor light 2
Fused spur with neon light 3
13amp socket plug 2
Double socket chrome 35
Double socket white 6
Cooker switch chrome 1
6mm cable for cooker 10M
6mm armour cable for garage 12m
Coaxial cable for Tv 50m
Coaxial socket for satellite 2
Electrical trunking 75 x 50mm - 2.4 metres 2.4m
Carbon monixide detector 1
50 pieces of open Grommet 25mm
2 Gang External plug socket 1
Not read all the replies... but non fire rated downlights?
not necessary unless the ceiling is the boundary of a fire compartment. e.g. in a garage with a room above, or if the room/s above are separate dwellings.
Reply to Wiring a 5 bedroom house in the UK Electrical Forum area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
