Wiring a 5 bedroom house | Page 2 | on ElectriciansForums
Discuss Wiring a 5 bedroom house in the UK Electrical Forum area at ElectriciansForums.net
omoeko
London
Hello Everyone,
I am not sure of the etiquette here on the forum, but I would like to start by extending warm greetings to everyone in the house. This forum is very useful for me and I have learnt a lot from it.
I would like to ask a question, its about the list of materials required to wire a 5 bed house. I have the list below, and would like to know if its correct etc.
3/4 double sockets per bedroom, and everywhere will have spot lights apart from the bedrooms. I also plan to use a double electric oven, which is rated at 4,400W and hence a 6mm cable needs to be used. The distance is about 10m from the board to the kitchen. Below are the oven specification.
Energy efficiency class (2010/30/EC) - cavity 2 : A Energy consumption per cycle forced air convection - cavity 2 (2010/30/EC) : 0.80 Energy efficiency index (2010/30/EC) : 112.9 Energy efficiency index cavity 2 (2010/30/EC) : 94.1 Electrical connection rating (W) : 4400 Current (A) : 20 Voltage (V) : 240 Frequency (Hz) : 50
Description Quantity
Non fire rated spot lights (Lounge) 10
Non fire rated spot lights (hall by door) 4
Non fire rated spot lights (family living area) 12
Non fire rated spot lights (Kitchen) 8
Non fire rated spot lights (Upstairs landing) 6
Non fire rated spot lights (Downstairs toilet) 4
Non fire rated spot lights (Utility room) 2
Bathroom spotlights (Upstairs bath) 6
Bathroom spotlights (Upstairs Ensuite) 4
External spot lights for outside 6
Pendant light 8
Smoke Alarm 2
Heat Sensor 1
Extractor fan 3
12/15 way board with MCB's 1
Kitchen Extractor Chimney 1
Shower shaving socket 2
Isolator for extractor fan 3
1.5mm brown cable 100m
1.5mm blue cable 100m
1.5mm GREEN/YELLOW cable 100m
3 core flexible cable 50m
2.5mm 3 core cable 200m
1.5mm Twin and earth cable 200m
2.5mm blue single core cable
2.5mm brown single core cable
Earth bonding
10mm green earthing
2 gang switch 4
3 gang switch 1
1 gang switch 8
1 gang switch white 2
Outside floor light 2
Fused spur with neon light 3
13amp socket plug 2
Double socket chrome 35
Double socket white 6
Cooker switch chrome 1
6mm cable for cooker 10M
6mm armour cable for garage 12m
Coaxial cable for Tv 50m
Coaxial socket for satellite 2
Electrical trunking 75 x 50mm - 2.4 metres 2.4m
Carbon monixide detector 1
50 pieces of open Grommet 25mm
2 Gang External plug socket 1
Dont be so negative and quick to judge, i was given a list of materials by my sparkie and I thought it would be good to have it checked by someone else to ensure its correct etc.
Hi omoeko. Welcome to the forum.
No one is being negative, (as Murdoch said) just realistic.
Why isn't the electrician getting the parts?
Omoeko
No your list the one your Electrician has given you is sadly not a list that a professional Electrician would have provided:
You said in your original post that the cooker is some 10M from the CU (fuseboard) and has specified 10M of cable, that statement alone is confusing, the distance may be 10M but by the time the Electrician had navigated corners obstacles he will undoubtedly find whilst running that circuit would be more like 15M or 16M in length, single cables? whats all that about? 25mm grommets 2.5 3core, shower shaver sockets, all smack (and I'm sorry to be so blunt) of someone who knows little if anything of wiring a domestic dwelling, it's plain to see that the amount of cable someone has specified is not only the wrong sort of cable, but the amount is know where near the amount needed for a 5 bedroom house. This Sparky you talk of where does he come from? because he certainly sounds like knows nothing. nd I'm not being negative, just truthful.
This is what he told me, he measured it and said 10m of cabling to the CU. Excuse my language.
The shaver sockets are things that i have put in so I do not forget.
What cables are the wrong type here ? I have only asked for spot lights, and I dont know if he has made a mistake.
Omoeko
Why is that ?
They come from a well known electrical distributor.
Where do I start? the single cable you talk of, unless it's insulated AND sheathed, it would be of little use to you unless you intended to run the cables in a continuous conduit system, the 3 core and earth 2.5mm2 you also speak of what is the intended use for that? The SWA as well, is the Garage remote from the 5 bed roomed house? the Fuse board no mention of RCDs, bonding?what size? green earthing what's that? I could go on, but unless you bite the bullet and get a proper professional quotation, you will be wasting 1000s of pounds cash as well as your time. Without any wish to rain on your parade, you clearly have very little idea of what you are doing, or intend doing. Sorry to be so blunt but thats how I see it.
From my notes
Its a conduit system buried into the walls using a channel or something like that.
I thought the 3 core and earth is used for multiple switches ? Not sure.
Also, the 3 core cables isn't that the one used for double sockets etc ? I feel this is the one that someone previously stated is not enough.
Reply to Wiring a 5 bedroom house in the UK Electrical Forum area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
