V
vicar
Morning all,
This looks like the place to get some correct info for my building project.
Hence the name Vicar we are renovating an old church.
My question is i have 97 m2 upstairs and would like to know if i can have 1 ring main to service the 4 upstairs bedrooms & gallery hallways my electrician said i should be splitting it into 2 rings i cant find out if it has to be split or not as some of the wiring on this ring is allready done by myself and was unaware i would need to split the ring its a pain as some of the walls are allready plasterboarded.
Is this nesessary i.e a limit to how many sockets on a ring or area to total sockets?
The downstairs area is 180 m2 and we have split the rings into 3 he said it was due to the loading on 1 ring main & long cable runs.
The kitchen will be a separate ring.
Also here in scotland the height of our switches should be between 900 & 1100 mm from FF level my question is what about the underfloor heating controls and the controls for the HRV system or any other control panels do they have to be at the same height or can they be higher on the walls.
I know that the switch & socket heights are for disabled access but cant imagine that the switches and controls would all have to go in the same row on the wall? or do they my electrician thought controls could be at 5ft high from FF level to pass building control but im not sure & thought i would ask here before i called my unhelpfull council.
Many thanks in advance for any advice,
Rgds.........
The Vicar.
Rgds.........
The Vicar.
