Wiring Hot Tub | Page 2 | on ElectriciansForums
Discuss Wiring Hot Tub in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Did some of these hot tub not require their own TT putting in as well?
Measuring the resistance of the heater and clamping it if need be may shed light.
Your saying a three wire system do you mean the supply to it (inc earth) or the feed splits into two live feeds with a shared nuetral (making3)
Hard water, the friendly hot tub repair man suggests Calgon:wink5: seriously, probably corroded to death, causing a short circuit to earth.
ok yes happy with that got a feeling that the hot tub was an import.
TBH i have not come across a uk made one yet, all seem to italian or spanish or american
Took me a while wire one up once that the instructing were in italian worked out black was live and white was neutral. so much for harmonised colours.
will try to flush the pumps out then that sounds good other than that there is no short in circuit, tested the sub circuit run to garage board and its fine tested individual circuit and is fine.
So what the Manufacturers name of this Hot Tub, and the model number?? Perhaps then, ...someone can then give you far better information which is based on actual data... lol!!!
What is the floor made of, which this Hot Tub stands on, Bare ground, Grass, Concrete, Paving tiles, Wooden decking etc??
Right been over to see the hot tub myself and what he told me is ******** he got of the internet and what he thought was tripping!
This is the situation with the Hot Tub:
Make: Balboa Water Group
Ran from garage consumer unit from main board in kitchen via a 50amp mcb to the garage consumer unit which also has 50amp mcb (so no discrimination) then to an isolating switch for the hot tub then to hot tub.
It is fully earthed and is protected by a 30 mA rcd, performed ramp test and ittrips at 23.0 mA.
It is ran in 10mm Armoured cable so plenty big enough.
Hot tub runs fine and starts up you can select the 2 modes of bubbles and it works fine all the lights are on it works fine, when the thermostat clicks the heating on, it shows the light and stays on for about 30 seconds then trips the Rcd.
Sounds like the heating element is on its way out. Is it new or second hand? How old is it?
Hot Tub Tripping
Read more: http://www.electriciansforums.net/e...ons/62192-wiring-hot-tub-2.html#ixzz24TiygYrk
Re: Hot Tub Tripping
oh, no, have to agree again. think i'm going to have another heart attack.
heating element , as mentioned , is toast.
and......
GFCI = ground fault circuit interupter = rcd ;-)
i've had a flick through the USA wiring regs or National Electric Code as its known , and boy is it a heavy read lol , 3 times thicker the uk 17th edition.
i lead a sheltered life.
Reply to Wiring Hot Tub in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Electrician Jobs TT supply for hot tub
Thanks for the advice so far. I now have a local qualified electrician engaged with this and an installation plan for TT earth at the hot tub and...
To the OP, the majority of French rural properties are TT with the connection exposed to the elements, with the below disconnection device bolted...
