Wiring lights in flat with concrete ceilings | Page 2 | on ElectriciansForums
Discuss Wiring lights in flat with concrete ceilings in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It's already been said, but...
Asbestos was prevalent in artex until approx 20 years ago. Get it professionally tested and removed if necessary. Then batten and board as per post #2. Don't disturb the artex in an way until you know what you're dealing with.
Edit: Actually, it may be 30 years.
Still an offence under the control of asbestos regs
under said regs its also an offence to bin those mem bs3036 fuses with the 1/2" square of asbestos in them.....how many of them have been binned over the years?
Said boards are incredibly prevalent round here....especially in "lower end properties", old higher end stuff tends to be wylex....and mostly the residents have no clue that there is asbestos in said boards...
An older relative of mine used to steam strip artex with asbestos as part of his job.
[QUOTE
An older relative of mine used to steam strip artex with asbestos as part of his job.[/QUOTE]
My father in law used to renovate old farm buildings years ago. These places contained loads of asbestos boards but no-one was aware of the dangers back then. Died far too early. Enough said!
Did one of these a few weeks ago, we bunched the cables onto the ceiling with Christmas trees and cable ties and the chased down the walls. They then reboarded the ceilings with wooden batons as a spacer and it ended up looking great.
Done a few of these sort of jobs in Richmond and the builder there screwed 2 x 1 battens to the concrete ceiling but then cross battened the other way, that way you can get all your cables in both directions without drilling shallow timber
Concrete ceilings normally only get a thin skim. Plaster isn't used, i forget the generic name for the stuff but it tends to be white or grey in colour!! Anyway, nowhere near the thickness to sink a cable in to it.
Not sure why you need to chase anyway, surely there is a conduit system in place, that would include lights to switches??
Reply to Wiring lights in flat with concrete ceilings in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Not sure what you mean by pre-IP? as IP guidance was introduced long before 12v halogen downlights became 'fashionable'. That aside I would ditch...
I was considering that, however the loft isn't boarded, not exactly the lightest 🤣 I was hoping I wouldn't have to do that but maybe that's the...
