Wiring Question | Page 2 | on ElectriciansForums
Discuss Wiring Question in the UK Electrical Forum area at ElectriciansForums.net
David916
Orangevale, California
Hi, I'm trying to add a switch that can control my bi-directional 110v motor.
I bought this joystick from Amazon but it doesn't come with instructions.
If anyhow can give me a hand, I would really appreciate it.
When I switch the Black and White wires on terminals #1 & #4, that changes the direction of the motor. Just didn't know how to wire the joystick.
Had a serious brain injury and it's hard for me to figure out new things so If you can break it down in the most simplest way possible, that would be awesome.
Thanks,
Dave
  • [ElectriciansForums.net] Wiring Question
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Can you post some photos showing the actual wiring?
The lights dimming and it not tripping the breaker is a concern in any case. That is a 2.2A (running current) motor so should be on something like a 10A fuse or breaker at most. What is the supply?
Reply to Wiring Question in the UK Electrical Forum area at ElectriciansForums.net
It possibly be a sheet rock screw. The NEC requires all holes cut in the studs should be no less then 1 1/4 inches from the studs and if any...
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
