woah! Danger present with BG outdoor light switch | Page 3 | on ElectriciansForums
Discuss woah! Danger present with BG outdoor light switch in the UK Electrical Forum area at ElectriciansForums.net
daveb
Aberdeenshire
Thought i'd share this one that happened to me today....
Was wiring up a customer gazebo with BG weatherproof fittings (light switch, sockets, JB and mains board). Anyway, all went fine and was on to testing the circuits.... circuits all tested fine.
The lighting cables were terminated into a JB for the time being as the customer does not have the lights yet. So, once I had finished and just by chance i thought i would use my voltage pen on the connectors just to prove the light switch was off. Pen lit up but the switch was off? Scratched the head..... used my voltage tester and was getting 108 volts with the switch off!
The BG outfdoor light switch has a neon on it via a resitor on the lead between common and one way terminal..... guessed that this was the problem rather than a faulty switch so removed it which in turn completely removed all voltage when the switch was off.
Very dangerous if you were relying on the switch to isolate the power so thought i would share.
Anyone else come across this before??
Both methods have there advantages. When we do new builds 9/10 times the switch is fed. When doing rewires with a pendant in each room we normally 3 plate the light as less to get down to the switch.
What I find easier still for rewiring ground floor lights Lee is a central JB with a cable from each light,switch and the supply back to it. A proper old fashioned method but of course I'd use a maintenance free box with Wagos or Ideal push in connectors and glands. If it's a normal adaptable box I might write 'MF' on it. :D
arghhhhh!!!....... i've come across one of these on a job a couple of times. They've been called an "octopus box". Complete nightmare trying to suss them out!!!
They're ok if done methodically and neatly Dave, I'd also put a label at the CU detailing the location and method used, it could be in an upstairs cupboard if available rather than under the floor.
Always used to say 4' 6" or 't!t height' for light switches. :)
Shins to ----. There's ya zones. ;)
Spider method. Seen a few spots wired like that. Never a full floor!
Why s nightmare? Lighting circuits are very simple to work out, it's just a few switches and lights.
If you find a central JB on a lighting circuit to be a complete nightmare then how on earth do you cope with simple control systems?
You my friend, are so unbelievably arrogant and seem to believe you are some superior electrician with all the knowledge in the world. Really don't know how you are allowed to post on here without being banned. If you can't reply in a nice manner then why bother? You're either very insecure or a very small man. Everyone else on here keeps the posts civil - why can't you?
Davesparks, why don't you just troll off somewhere else. Sick of your superior smug replies to everybody. It got like this before and all that happens is people start leaving the forum.
Guys, let's Keep it civil and move on please. If a member isn't happy with another members comments then please feel free to use the report button, much better than derailing a thread, cheers lads.
Reply to woah! Danger present with BG outdoor light switch in the UK Electrical Forum area at ElectriciansForums.net
