Wood burner-detector required? | on ElectriciansForums
Discuss Wood burner-detector required? in the UK Electrical Forum area at ElectriciansForums.net
SSE
What detector should be fitted in a room with a wood burner? I know a Carbon Monoxide detector is required but what should be installed out of a smoke detector or heat detector?
As Lankywill states, smoke is a problem.........A sealed flue unit should not cause any problems, but when you open the stove door to refuel, this could be a problem with false alarms....suggest an optical or multi sensor at least 2-3m away from the fire. To give some early warning. You may have to change to a heat if false alarms become a problem.....so its really suck and see....A CO detector is a must here, no matter what else is installed.
No hasel5 , you are correct, hence why it is a suck it and see situation, if there`s plenty of air flow in a large room, and optical will possibly be fine.....closed small cottage type room, could be a problem.
Surely this would depend on the layout of the house?
But a CO2 will be required for sure and only needs to be a battery unit
Tin hat on
CO mate. CO2 is carbon dioxide which is non-poisonous.
Thanks for replies. Smoke detector seems to be the general consensus so will go for that. Worst case scenario is it gets triggered off easily in which case I'll swap for a heat detector. Thanks.
I fit heat detectors in this scenario but that based upon Scottish Standards. If it's any help, Aico now do a combined unit though. Not sure how smoke from a fire would affect it.
Reply to Wood burner-detector required? in the UK Electrical Forum area at ElectriciansForums.net
This is it though…. To put one following the letter of the law, so to speak… would be a smoke in the hallway outside the bedroom door… then a heat...
Found the cause of the tripping…. Just jointed them through… all clear now. Removed the smoke detectors completely. They were due to be...
