Wooden cladding / multi tool | on ElectriciansForums
Discuss Wooden cladding / multi tool in the UK Electrical Forum area at ElectriciansForums.net
Dustydazzler
Supporter
V.Nearly Esteemed
Surrey
I have been asked to price a massive rewire and the entire downstairs is wooden clad walls. The wooden cladding is staying, I have to cut new boxes into it.
Will a multi tool cut the cladding neatly and quickly ?
I have never used a multi tool so any advice appreciated
This type of French farm house style cladding
Iโ€™ve got about 45-50 back boxes to cut into it, Iโ€™m thinking a multi tool might be the best tool?
if just 1 or 2 boxes I would chain drill with a sharp drill and the chisel out but will take ages this way
  • [ElectriciansForums.net] Wooden cladding / multi tool
I had a job like that once, after various experiments I ended up drilling a 10mm hole in diagonal corners with a spade bit then using a jig saw on top of a small bit of board to limit the depth. That was quick and not too noisy. By the end I was flying through them.
A multitool would definitely do it cleanly but I'm not sure I'd say it was terribly quick.
thanksc
i donโ€™t really want to spend ยฃ100 on a new multi tool if itโ€™s not going to make the job quicker
my limited experience with multi tools is they are very noisy and the blades blunt very quickly if you hit a bit of block wall
For that amount of cuts Iโ€™d buy a 240v multi tool, a B&Q special would be fine for that.....I had the same job last year on a 17th century place down here (Nelsons mistress lived there apparently) on that job I ended up doing the whole thing in quinetic ?
It would have certainly been quicker to cut the jigsaw blade! My only comment is that most have a 1" stroke so if you make it too short it leaves the slot you are cutting - steady hand required!
Wouldnโ€™t be without a multi tool now. Just done a small job putting extra socket in living room for Fused spur and TV mount. Didnโ€™t want to use disc cutting dust machine. Used a multi tool masonry attachment to get clean cut through plaster and was lucky that it was really soft block underneath. Clean cuts either side of chase and quick knock out with SDS chisel.
45-50 boxes in that stuff? Multitool will pay for itself on this one job - just bear in mind that they eat batteries, so make sure you have a few spare if planning on cutting everything in one day.
*Buy decent blades and one will make all those cuts effortless.
Maybe I need to spend more on multitool blades ?
Cheap blades have their uses (and expensive doesn't necessarily mean good), but there's nothing worse than blades which aren't fit for purpose.
In my opinion Saxton are a reasonable blade for the price if you don't dog them . But Fein take the ribbon.
Reply to Wooden cladding / multi tool in the UK Electrical Forum area at ElectriciansForums.net
Could you tell her you're gonna give it a quick test as she is unsure where the paperwork is? That would give you a better idea of overall...
Its important to remember that a plug top fuse is just a rewireable fuse that's convenient to change and shouldn't be confused with a HRC fuse...
  • [Speak๐Ÿ—ฃ๏ธ AA]โ„ขHow do I speak to American customer service?24&7!!Fast!!Service
    ๐“ฃ๐“ธ ๐“ฝ๐“ช๐“ต๐“ด ๐“ฝ๐“ธ ๐“ช ๐“๐“ถ๐“ฎ๐“ป๐“ฒ๐“ฌ๐“ช๐“ท ๐“๐“ฒ๐“ป๐“ต๐“ฒ๐“ท๐“ฎ๐“ผ ๐“ต๐“ฒ๐“ฟ๐“ฎ ๐—ฟ๐—ฒ๐—ฝ๐—ฟ๐—ฒ๐˜€๐—ฒ๐—ป๐˜๐—ฎ๐˜๐—ถ๐˜ƒ๐—ฒ ๐“ฒ๐“ท ๐“ช ๐“บ๐“พ๐“ฒ๐“ฌ๐“ด ๐“ฝ๐“ฒ๐“ถ๐“ฎ, ๐”‚๐“ธ๐“พ ๐“ฌ๐“ช๐“ท ๐“ฒ๐“ท๐“ฒ๐“ฝ๐“ฒ๐“ช๐“ฝ๐“ฎ ๐“ช ๐“ป๐“ฎ๐“บ๐“พ๐“ฎ๐“ผ๐“ฝ...
  • What is the refundable option on ๐”ผxpedia? Cancellation Policy ยฎ
    What is the cancellation policy for ๐”ผxpedia? ๐”ผ๐•ฉ๐•ก๐•–๐••๐•š๐•’ ๐• ๐•—๐•—๐•–๐•ฃ๐•ค ๐•’ ๐•˜๐•–๐•Ÿ๐•–๐•ฃ๐•’๐• ๐Ÿค๐Ÿฆ-๐•™๐• ๐•ฆ๐•ฃ ๐•”๐•’๐•Ÿ๐•”๐•–๐•๐•๐•’๐•ฅ๐•š๐• ๐•Ÿ...
  • [[Official~Expert]] Contact QuickBooks Desktop Support Customer Service HElp QB Support
    To contact QuickBooks Desktop Support via phone, dial โœ…๐Ÿ“ž +1-844-881-9274 +1-844-881-9274 or #...
