Wooden cladding / multi tool | Page 4 | on ElectriciansForums
Discuss Wooden cladding / multi tool in the UK Electrical Forum area at ElectriciansForums.net
Dustydazzler
Supporter
V.Nearly Esteemed
Surrey
I have been asked to price a massive rewire and the entire downstairs is wooden clad walls. The wooden cladding is staying, I have to cut new boxes into it.
Will a multi tool cut the cladding neatly and quickly ?
I have never used a multi tool so any advice appreciated
So, I have borrowed a multi tool off a mate and had a practice at cutting a 2g box into an off cut of old 18mm chipboard. It cut through it lovely. Relatively straight clean cut lines and not to much mess.
A bit noisy but Overall it did the job better than I expected…
if I get the job with the cladding I think I will invest in a cheap multi tool.
a jigsaw with a cutdown blade would probably do the same job but I think a multi tool offers a bit more flexibility to get into tight areas
i got 2 mulititools. a 12V aldi one (cheapo) and a 18V AEG (same batteries as my combi drill). the AEG one is awesome and the head can be swapped over for a 90 degree drill head.
Reply to Wooden cladding / multi tool in the UK Electrical Forum area at ElectriciansForums.net
Could you tell her you're gonna give it a quick test as she is unsure where the paperwork is? That would give you a better idea of overall...
Its important to remember that a plug top fuse is just a rewireable fuse that's convenient to change and shouldn't be confused with a HRC fuse...
