R
rocker
The helacons I use require some serious twisting and a lot of pulling to get out.... I can't see them coming out of anything unless you want them to.
Try this small company Wagobox Home of The Maintenance Free Junction Box very good will send you a free sample to try out in your homewhere do you buy your wagos and which kit do you recommend, will be handy for a job i have coming up but have never used them before and would like to get best value for money. Will be using them for some 1.5 t&e but would like to get a good selection to keep on the van.
the Inspector from Elecsa/ECA talked to me about wago connectors and he was all for them!
i asked the question about plastering them into a wall and his advice was YES they are designed for that and as long as they are protected in an enclosure like a chocbox or similar they can be treated in same way as crimped connections as the effect of moisture from the plaster and also the aggressive nature of the plater may cause damage to the connections!
he also said that due to the design nature of the wago they need not be enclosed in an enclosure if say placed in a loft area or a partion wall providing they have been terminated correctly and pushed fully home with no copper on show as per manufactures instructions!
My 2 cents worth...
I'd agree
A crimper can be considered as a compression tool, resulting in a maintenance free joint. As mentioned in 526.3
A wago cannot really be considered maintenance free as the cable can be pulled out and so are vulnerable to vibration. Proper anchoring could maybe fix this issue, but then there is the problem that can arise from excessive overload. Granted these wago's are designed to an operating temperature, but if cables do get overloaded it will be at there weak point where they will likely char and/or snap, which is most likely in the wago. I have seen this before twice already.
I think it's early days with these connections for us to be happy filling them into walls never to be seen again without an understanding of their longevity.
That seems like nonsense as wago say they should be in an enclosure, and more importantly, there will be no fault protection at the connections?
I've been using Wago's for years and have never had a problem
Thry don't pull out, cause hot spots,or break the cables, compered to some of the crip joints if seen over the years there a lot more reliable
They do pull out, and they do heat up. I have done, and seen this happen.
What's a crip joint?
Got 100 wago's (1.0mm-2.5) off ebay for 12 quid.I also pay around 60p each for choc box in bulk. Had the invoice off City of Electrcial for some choc boxes i bought there, 4pound each - 50% discount= 2pound= robbing gits.
NO WAY!! (about no enclosure required) states that the connection and cables need to be protected. So connector doesnt comply in its own right and the bits of cable where the sleeving is stripped of requires protection........thats the reason for a JB!!
I got told from an NIC inspector that it was ok to terminate my downlighters in the lever clamp wago's with no need to add a choc box or wagobox. For months I have been using both but he has told me it is no longer required as the wago's, if terminated correctly have no exposed live part. However I believe in belt and braces and for the sake of a few extra minutes and perhaps £30 on a quote, still put them inside an enclosure.
Off topic but he also told me I no longer had to have my meter calibrated every year so long as I have a known test rig or circuit(s) and keep a record of test results. Not sure if both are true or whether he had been on the Lambrini!!!!
Something smoked by a South Californian gang member?
