OP
bugsy
They do pull out, and they do heat up. I have done, and seen this happen.
What's a crip joint?
I can only assume they have been installed incorrectly then, crip joint - crap crimp
Discuss Words from the Inspectors Mouth about Wago! in the Electrical Tools and Products area at ElectriciansForums.net
Got 100 wago's (1.0mm-2.5) off ebay for 12 quid.I also pay around 60p each for choc box in bulk. Had the invoice off City of Electrcial for some choc boxes i bought there, 4pound each - 50% discount= 2pound= robbing gits.
NO WAY!! (about no enclosure required) states that the connection and cables need to be protected. So connector doesnt comply in its own right and the bits of cable where the sleeving is stripped of requires protection........thats the reason for a JB!!
I got told from an NIC inspector that it was ok to terminate my downlighters in the lever clamp wago's with no need to add a choc box or wagobox. For months I have been using both but he has told me it is no longer required as the wago's, if terminated correctly have no exposed live part. However I believe in belt and braces and for the sake of a few extra minutes and perhaps £30 on a quote, still put them inside an enclosure.
Off topic but he also told me I no longer had to have my meter calibrated every year so long as I have a known test rig or circuit(s) and keep a record of test results. Not sure if both are true or whether he had been on the Lambrini!!!!
Reply to Words from the Inspectors Mouth about Wago! in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
