Working with old imperial conduit... | on ElectriciansForums
Discuss Working with old imperial conduit... in the UK Electrical Forum area at ElectriciansForums.net
DNS1
A mate just moved into a flat and has asked me to sort out a few things with the electrics, mainly convert some single sockets to doubles.
Unfortunately for me, everything has been run in singles in metal conduit without a CPC.
Need to get hold of some backing boxes with the appropriate sized knockouts to take the imperial conduit fittings correctly, but having a hard time finding them at my usual suppliers.
Anyone got any suggestions?
Cheers!
Cheers!
They used to do 'conversion couplings. Someone may have some, somewhere.
Good luck
When I said drill the back box there was no mention of a 20mm cutter, that's why I said you should use a step /cone cutter. Use the largest drill bit that you have, and then use the cutter to the drill to the correct size.
How is the conduit terminated? A coupling and male bush or two lock nuts and female bush? Either way if you’re worried about continuity use an earth tag (banjo as you youngsters call them) with a fly lead. A cone cutter is the best bet to resize the knock out, but as E54 said, it’s a gnats knackers out of size.
Sorry but I’ve promised my imperial stocks and dies to Glenn.
Reply to Working with old imperial conduit... in the UK Electrical Forum area at ElectriciansForums.net
On putting a date on old cables the makers used to use a letter system. This was certainly used on pilc cables and sometimes in lead sheathed...
It applies to commercial if it shares the same supply as a dwelling.
