Working with old imperial conduit... | Page 2 | on ElectriciansForums
Discuss Working with old imperial conduit... in the UK Electrical Forum area at ElectriciansForums.net
DNS1
A mate just moved into a flat and has asked me to sort out a few things with the electrics, mainly convert some single sockets to doubles.
Unfortunately for me, everything has been run in singles in metal conduit without a CPC.
Need to get hold of some backing boxes with the appropriate sized knockouts to take the imperial conduit fittings correctly, but having a hard time finding them at my usual suppliers.
Anyone got any suggestions?
Cheers!
Why not use converter sockets?
That's one solution, although they can be a source of nuisance as i've found in the past. They aren't very robust for heavy use outlet points. If wanting to do a proper conversion and installing new double back boxes, i really can't see this as being much of a problem for any competent electrician....
I'll second this. I installed single to double converter sockets in my kitchen as a quick fix when we moved in. Within a year, all 3 just had one side working, so effectively back to singles, lol.
Very cheap build quality and not worth it. Mine were made by Clipsall by the way.
When I said drill the back box there was no mention of a 20mm cutter, that's why I said you should use a step /cone cutter. Use the largest drill bit that you have, and then use the cutter to the drill to the correct size.
Can't see any mention of a 20mm cutter.
Interesting cone cutting a 3/4 hole in a 20mm knockout...
Just measured the knockouts in a box I nabbed earlier. It has both 3/4" AND 16mm openings and it's the 16mm which are in use.
Conduit is currently terminated with a coupler and attached to the box with a male bush. Did look at just trying connecting it to a 20mm knockout, but no chance, it fits straight through!
Next option is use the existing bush to clamp on a banjo, and then run a strap into the box as if it was a CPC. Sound reasonable?
By the way, I broke the ring measured R2, 0.14ohms so no problem there.
Old 5/8 inch then. Have a real job on getting couplings and bushes for that, I feel.
Not much difference between 5/8 inch and 16mm. Try 20mm/16mm reducer...might just fit.
There are several ways to get around this minor problem!! It's completely do-able
Agreed! I'm just paranoid that I'm going to do something that would be frowned upon!
Sounds stupid, but I don't want a sparks to turn up in 20 years time for a full rewire, look at my work and think it's cowboy!
Washers are a good idea (so good I thought of it earlier!) just couldn't get any the right size!
i think i used to get around it with 5/8 locknuts.
probably as scarce as police at a gypsy camp these days though.
there was adaptors for these with usually a 5/8 female to 20mm male thread if i remember rightly
lewden made them
Reply to Working with old imperial conduit... in the UK Electrical Forum area at ElectriciansForums.net
On putting a date on old cables the makers used to use a letter system. This was certainly used on pilc cables and sometimes in lead sheathed...
It applies to commercial if it shares the same supply as a dwelling.
