Worldwide ring mains | Page 2 | on ElectriciansForums
Discuss Worldwide ring mains in the UK Electrical Forum area at ElectriciansForums.net
K
KevinS
Quick question here, does anyone know if any other countries use ring mains
reason I ask, I have made a proto-type socket where you can do your continuity checks and r1+r2 tests WITHOUT taking the socket off.
i don't know how much more money and time to spend on this idea
Kevin I agree with the cables coming out as the terminals are tightened, (i use Crabtree and these seem to push the conductor out as I tighten them but that's another topic) but when testing why would you be disconnecting conductors at the socket? You only need to disconnect at the db
Guitarist,
my initial thoughts were:-
the socket would be fitted during the initial wiring, after the job was complete you could take your readings, but the main reason was, any periodics that needed doing the circuit would not needed to be disconnected/taken apart
i was more thinking along the lines of student accommodation etc where a periodic would be done more often.
but what would the harm be fitting one to every circuit (ring)
Kevin, I have a rough idea of what your thinking of, instead of a socket you'd be better to have the same stuff in it but install it on the ring near the consumer unit, how ever I think your trying to solve a problem that don't really exist.
so it's a double socket, with 6 terminations at the back (2 L 2N and 2 CPC) and some way of testing the ring end to end ?
and you have to fit this to every point on the ring before this system works? i'm struggling to comprehend this. whats wrong with end to ends a the board, cross connect fig 8 and measure at each point(no need to remove any fronts anyway)
There is nothing to stop a wire coming out of the db. (much easier to spot I agree)
I agree the db is the best place to test but some db's are a right rats nest and it's easier to go to a socket.
Surely it must be easier not having to remove/disconnect wires/reconnect/ replace.
IMO, this will not be popular.
There are hundreds of different socket designs, and everyone preferences are different. It would be difficult to make the socket suitable for most installations. Perhaps a device near / in DB would be more practical?
With regards to Ring Mains,
I can not see them coming to an end anytime soon with the current prices of copper. It was the high copper prices that made us introduce ring final circuits. I can see radials being the more common option in the future as many modern homes (especially kitchens) have many high current electrical items in use that may put pressure on ring final circuits.
harmonisation with european standards
if we were prepared to change the whole countries wiring colours to keep brussels happy then phasing out rings will be a piece of cake in comparison.
lets see what happens when the 18th regs comes around.
if it aint broke dont fix it,tho some people need to justify they jobs and scams i agree.
Don't think rings will disappear in the very near future, but I think less and less will be installed, that's why I am thinking I am wasting my time and money pushing my idea any further forward
Reply to Worldwide ring mains in the UK Electrical Forum area at ElectriciansForums.net
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
If it's going to be an emergency stop and not just a stop, then other factors come into play depending on what sort of machines the emergency stop...
