Worldwide ring mains | Page 5 | on ElectriciansForums
Discuss Worldwide ring mains in the UK Electrical Forum area at ElectriciansForums.net
K
KevinS
Quick question here, does anyone know if any other countries use ring mains
reason I ask, I have made a proto-type socket where you can do your continuity checks and r1+r2 tests WITHOUT taking the socket off.
i don't know how much more money and time to spend on this idea
This old chestnut of a ring becoming open circuit, in all the years i've been in this industry i've never come across such a scenario.
I come across it quite often actually, not in houses but in commercial and industrial premises...
Either a break in just one of the conductors or all of them...
Quite common...the last EICR I did had 2 out of the 4 rings like this...
Sent from my Xperia S using next doors WIFI.
I can only ask HOW did they become open?? Surely using that analogy, it could also be applied to a Radial circuit.
As i have stated, never seen a ring becoming open circuit. Not saying it can never happen, but i would say that it's a lot rarer than some would have us believe. Can't really grasp how a professionally installed and tested ring circuit can suddenly go open, without someone's intervention...
Very true...As you mention its mostly down to peoples intervention, extending the ring incorrectly etc and as you rightly say the other faults could happen to a radial such as broken conductors, brunt out etc etc but as is being said with a ring you then theoretically have to radials protected by a 32A OPD...
I'll opt for the horses for courses option they both have there pro's and con's it just depends and the jobs demands as to which is installed...
Reply to Worldwide ring mains in the UK Electrical Forum area at ElectriciansForums.net
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
If it's going to be an emergency stop and not just a stop, then other factors come into play depending on what sort of machines the emergency stop...
