Would this be acceptable? | Page 3 | on ElectriciansForums
Discuss Would this be acceptable? in the UK Electrical Forum area at ElectriciansForums.net
P
perry_bridges
Hi all,im currently an Apprentice and need some advice for a job that my boss is doing.He plans to put a fused spur on a 32a ring circuit to feed a CSU for a couple of sockets in the shed. The cable run is about 45 meters long using SWA (not sure what size).Is this acceptable because this doesn't seem right to me?cheers perry
He most likely just wants a light in his shed.. let install a 6 mm SWA from the CU stick a rod in, dig up the garden, wreck the house, just so the poor sod can see his potting plants...
Spur off ring, 4mm radial SWA. make sure RCD protected. let him pot the plants...
Now if its a work shop down there, well!!!!!!!!!! thats a diffrent storey
only thing is Edd....once he`s got light in there....wont be long before he`s regretting not having an outlet in there n all.....
give him some light..and he`l be up late at night.....
wirin up a dodgy socket outlet...lol...
perry....stop conjecturing....do your VD calcs as i asked you to....i have given you all you need...
you know your length of run....
you know what your Ib is
now check the mV/A/m in app f OSG...
work it out...no guessing please
the volt drop is under the limit
What was Glenns last 3 words of his sentence, and he was very polite too.
Reply to Would this be acceptable? in the UK Electrical Forum area at ElectriciansForums.net
Nothing wrong with it. Which manufacturers have you got this information from? What do you mean by trip speed? Fuses and MCBs can operate in the...
davesparks
