Discuss Would you bother to change this consumer board? in the UK Electrical Forum area at ElectriciansForums.net
- replace extractor fan in kitchen
- some rewiring (i.e. moving sockets) in kitchen
It was when getting quotes for this work that the electrician recommended installing a new consumer unit (and having everything tested).
that board was never new in 1993. more like 1980.
`has it been tested`?...what?..the C/u or the finals and/or subs from it?...Has it been tested recent? As stated above looks ok BUt what is on inside?.......why are considering changing are you having any work done....If so and new circuits, extensions, bathroom up grades, kitchens, garden installations would require RCD protection so in that case prob cost effective and practical to change whole board.
But dont presume everything ok because it looks good from outside, if you have not ever had a test carried out, or the last test you have paper work for is in 1976.....you might want to have a qualified electrician establish the safety and functionality on your electrical system. If its good then no reason why you cannot keep the board.
As example last job i went on, just needed few addional sockets in kitchen, builder was saying to me "ohhh its alright mate we just need couple sockets just extend it out nothing big"......i said i'll let you know ...on further investigation the fuse board which was exactly same as yours, looked great on inside took cover of and saw this...
Builder quickly moved on to HIS jobs and kept very quite. turns out WHOLE house was on one circuit and this i would say was a bad connection as all other cables were fine.......
still good to really see what was going on inside.....customer then said they wondered why they could smell burning last week............i sometimes wonder !
We have got some work in need of doing. It's mostly quite small bits and pieces:
- remove a light fitting in living room
- remove extractor fan from bathroom
Many thanks for all the help and replies.
i think it was called common sense Malcolm......too much reliance on `magic` RCDs ...where you can go through cables for fun and you dont even have to bother getting a value of loop.......well not a meaningful one anyway....I have often wondered what we did before RCDs that is used for Additional Protection came in vogue.
Yes I can remember the good old days when the hand cart was being pushed around town with characters dressed up to look like a species of bird with a large bell crying bring out your dead, with all these electrocutions, and when the dead were loaded onto the cart for mass burial into lime pits a red 'Ω' was daubed onto the door.
None of the above work requires an EICR, none of the above work, even in a kitchen or a bathroom requires Part P notification.
Totally agree that if the OP was looking within the next couple of years of having the place rewired, fitting a new kitchen that would require extra circuits or other major works then yes a new board would be prudent.
Totally agree that if when the sparks took that cover off and there were burnt cables, 6 circuits into a fuse (Now MCB) carrier then yes a new CU might be prudent.
But for this work, and no future work, for no signs of damage or over loading and unless there is a major design flaw where your Zs values, why is everyone saying "Get it out and put a new one in"?
Lol and you get a new pair of snips too!and who needs fancy MFTs when you can test RCDs and MCBs just by using a pair of snips?
sod it....just `sling it in`....hmm...them joints look good....should be about rite.....energise....cash in arse pocket....and its off to the next un....lolllland who needs fancy MFTs when you can test RCDs and MCBs just by using a pair of snips?
Reply to Would you bother to change this consumer board? in the UK Electrical Forum area at ElectriciansForums.net
