Would you use an old CU to extend cables. | on ElectriciansForums
Discuss Would you use an old CU to extend cables. in the Electrician Talk | All Countries area at ElectriciansForums.net
Horleyy
I recently inspected a job in a 1960s-era apartment building. Three of the properties have old Wylex rewireable consumer units (CUs) with Pyro wiring.
To minimize damage to the 50-year-old Pyro, which passed testing, I propose the following approach:
1. Utilize the old CU as a junction box.
2. Remove the internal components and install a DIN rail.
3. Extend the cables using DIN rail connectors.
4. Construct a wooden support in front for the new consumer unit.
I welcome your thoughts and suggestions.
I suppose you are doing this as there is no room to fit the new CU adjacent to the old one? It's just that the new one is going to be sticking out quite a bit, if its in front of the old one.
Limited space. It is in a cupboard. So they'll lose a bit of cupboard space.
I have done similar in the past, although it was side by side, not one on top of the other.
2 suggestions, they may / may not be suitable for the space available.
the lid of the old fuse box will have big holes in it when you have removed the fuse gear and main switch
I have screwed / pop riveted an aluminium sheet over the face of old boards in the past to seal up the big holes in the front.
when you construct the wooden support, use a sheet of ply on the front of it to mount the new board to.
pass the cables through the rear entry of the new board through a hole drilled in the ply.
use a couple of hinges on the bottom of the ply and then screw the top to the batons.
If you need to get behind it to fault find or check any of the cables / joints, you can undo the top screws and fold the new board down to access behind it.
Like the idea of hinging the ply. It was in the back of my mind that if there is a fault back there it would be a nightmare.
I was planning to bung the holes, and screw a blank plate over the main switch. But I like your idea better.
Reply to Would you use an old CU to extend cables. in the Electrician Talk | All Countries area at ElectriciansForums.net
Thanks for that information I'll have a look at.
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
Having all neutrals commoned on outgoing cables would be problematic where more than one RCD is present or where such protection is afforded...
7K
nicebutdim
N
i would split he tails and fit an additional 2/3 way CU to supply the garage/whatever. that way you could feed in SWA, installung RCDs as and if...
4K
You could probably get a pan assembly to fit in there and have a front cover made to fit over it by a sheet metal engineer.
davesparks
