Would you... | on ElectriciansForums
Discuss Would you... in the Australia area at ElectriciansForums.net
SSE
get a shock off a main earth that's disconnected from the cu in a tncs system when the main cu switch is off? Overheard someone at work talking about it today but never heard off it. (bear in mind I'm a beginner) :D
yep that's where you take the Ze reading
may have been static:D
you can get a shock off the bar alright when you pull the main earth-if there's a fault
only if thay is a fault as long you do safe isolation you be ok .. but you can get static of cables and floating earths that have voltage
A fault from the suppliers side? And concerning your earlier post why would you get a shock off bar if power is off? Maybe it was bar he got it from and not cable then.
Reply to Would you... in the Australia area at ElectriciansForums.net
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
