Leesparkykent
Nearly Esteemed
Any ideas people?
You need to check for the correct voltage throughout the order of how it's switched on both ch and hw, with out this it's all guess work.
Any ideas people?
Can somebody help me out please. I've been let down twice now by leccys in the past fortnight.
Has anyone got a diagram or know how to just get the central heating on, using the controls on the boiler. Basically override the 3 way valve, and by pass the thermostat and control panel.
its a Worchester Greenstar RI.
Thanks for your help.
Without seeing the system it is very hard to advise how to bypass the controls safely, some types of hot water storage need overheat protection as they can explode in a most dramatic fashion if they overheat.
The problem with a 3 port valve is that with it latched open manually it will be heating both DHW and CH without control.
You need to put a link between terminals L and LR to get the boiler to fire up.
But I should warn you that unless you are gas safe registered you shouldn't be removing the cover off the boiler.
Charming and the same to you Geordie!
Do you never watch rogue traders or watchdog that's what they say. And over on the plumbing forum if someone asks a question like this they always get closed and advised to get a GSR engineer.
I was only warning the guy not telling him not to.
Bollox!!! :laugh:
No just covering my back! If he blows himself up he can't blame me.haha, April fools?
Your the one who asked him what wires went where and gave him a wiring diagramWell you told him how to link out his boiler and he's not an electrician.
