Y plan with 2 port twisting my melons man | on ElectriciansForums
Discuss Y plan with 2 port twisting my melons man in the Central Heating Systems area at ElectriciansForums.net
stidge
Nottingham
Hi all, some help please. Wiring boiler on y plan (new Drayton mid pos) and an old Honeywell 2 port. Hot water works fine ( through dual stat).cannot get boiler to fire on heating, checked room stat, mid pos opening but on orange sw/l to boiler only getting 60-68 volts so obviously boiler not firing, have double checked all connections and been there far too long !!!!!! Any suggestions much appreciated cheers
hi is the two port a safety valve ie hot hw over heat, also which programer are you using
Hi justin I believe the 2 port is a safety valve, can't remember programmer name baxos or something ? With this system do I need to wire hw off from programmer
The hot water 2 port needs to open first when the clock is on then that will fire the boiler, the the oranges from both the 2port valve and 3 port need doubling up. Also white on the 3port is SL for the heating. I've wired hundreds of heating and now them inside out. If you still struggling ill do a diagram and just wire it to that all clock back are pretty universal in terms of connections on back plates
if it is a y plan then yes providing the 2 port is a safety, the voltage part its a back feed as with out hot water off to the 3 port the motor stays where it was last unless its sprung return
That's great Richard , if you wouldn't mind doing me a quick diagram.think I just have 1 or 2 crossed, the two oranges are doubled up for sw/l but the white I have coming from room stat call !!
Hi pal I've got a diagram from the ozoho****er.co.uk to put on but I cannt seem to post it.sorry. if you google ozo wiring diagram PDF it'll lead you to it that's the one I've memorized. I'm on my iPhone so no idea how to post pics. Hope this helps nothing better than sorting a heating wiring fault out
Reply to Y plan with 2 port twisting my melons man in the Central Heating Systems area at ElectriciansForums.net
Certainly is!! And another thing .......... On the old Hive receiver the relay common is a separate terminal, whereas on the new Hive presumably...
The 4 pumps are :- 1. boiler to cylinder 2. C/H and UFH circulating pump 3. UFH dedicated pump after manifold 4. DHW circulating pump. (this just...
